You are here: Reference Manual > FME Server Web Services > Utility Services > Web Connection (SOAP Communication) Service > Web Application Properties
SOAP Service Properties File Content
# SOAP Service Servlet configuration file
# This file details the installation parameters of the SOAP Servlet.
# SERVER_NAME - The computer where the Transformation Manager is running. Can be specified
# as a network name (ie: "ATHENA") or an IP. The default value is
# "localhost".
SERVER_NAME={SAFE{fmeserverHostnameLocal}}
# SERVER_PORT - The port on which the Transformation Manager is running on the remote
# machine. This is an integer between 1025 and 65535.
# The default value is the default Transformation Manager listening port,
# which is 7071.
SERVER_PORT={SAFE{fmeserverRequestPort}}
# CONNECTION_POOL_EXPIRY - The length of time in seconds in which an FME Server connection remains idle
# before expiring from the connection pool.
# If a value of less than or equal to zero is specified, then there is no
# connection pooling.
CONNECTION_POOL_EXPIRY=300
# RESOURCE_PATH - This is the path to the textual resources of the log.
# This file stores all the messages that will appear in the
# log as well as their code.
RESOURCE_PATH={SAFE{resourcesDir}}
# MIN_TIME_BETWEEN_REQS - This is the minimal amount of time that a client
# must wait before sending another request. If a
# request is sent before that interval, it will be
# ignored. The time is specified in milliseconds.
MIN_TIME_BETWEEN_REQS=1000
# LOG_CONFIG_PATH - The folder path that contains the log file configuration.
LOG_CONFIG_PATH={SAFE{utilitiesDir}}/config
# LOG_FILE_NAME - The file name that the log files will have in common.
LOG_FILE_NAME=soap.log
#SECURITY_CLIENT_ID - The client ID assigned to this web service.
SECURITY_CLIENT_ID=service_fmesoap
#LOCALE_CONFIG_PATH - the path to the FME localization config file which contains the FME_LOCALE property
# If no file path or an invalid file path is specified, then the default system locale is used.
# If a valid file path is specified, the FME locale in the specified file is used.
# If there is no FME_LOCALE property in the file, then the default system locale is used.
# The language, country and variant are separated by underscores.
# Language is always lower case, and country is always upper case.
# Examples: "en", "de_DE", "_GB", "en_US_WIN", "de__POSIX", "fr__MAC"
LOCALE_CONFIG_PATH={SAFE{resourcesDir}}/fmeLocaleConfig.txt
#FAILOVER_SERVER_NAME - (Optional) The name of the FME Server host that is designated for failover.
# If connection to the primary FME Server is lost, the Service will attempt to connect
# to the specified FME Server host that is designated for failover.
# To use FAILOVER_SERVER_NAME below, uncomment the line and replace <failoverServerName> with
# the FME Server failover host name. Do not include the angle-brackets in the failoverServerName.
# For example: FAILOVER_SERVER_NAME=fmecore2
#FAILOVER_SERVER_NAME=<failoverServerName>
# CORS Shared Configuration File - File system path to the configuration file for cross-origin resource sharing that
# is itself shared by all FME Server services.
CORS_SHARED_CONFIGURATION_FILE={SAFE{resourcesDir}}/clients/cors.properties
################### SOAP Service Servlet configuration file END #####################
