• Administrator's Guide
    • Notices
      • Version Information
    • About This Guide
      • About FME Server
    • Planning an FME Server Installation
      • System Requirements
      • Requirements for FME Workspaces
      • System Architectures
    • Installation Options
      • Express Installation (Windows)
      • Express Installation (Linux)
      • Distributed Installation
      • Engine Installation
      • Silent Installation (Windows)
      • Silent Installation (Linux)
    • Upgrading FME Server
      • Full FME Server Upgrade
      • FME Engine Only Upgrade
    • Optimizing FME Server
      • Configuring the Number of FME Engines to Start
      • Adding FME Engines on a Separate Machine
      • Changing the Database Provider for the FME Server Database
      • Moving the Web Applications Server to Another Machine
    • Securing FME Server
      • Security Basics
      • Configuring Integrated Windows Authentication
      • Running the FME Server System Services Under Different Accounts
      • Using FME Server with a Proxy Server
      • Hiding External Content in the Web User Interface
    • Other Common Tasks
      • Licensing and Administration
      • Backup, Restore, and Migration
      • Notifications
      • Workflow and Resources
  • Reference Manual
    • Introduction
    • Notices
    • FME Terminology
    • FME Server Architecture
    • FME Server Ports
    • Directory and Account Permissions
    • FME Server Configuration Files
      • processMonitorConfigCore.txt
      • processMonitorConfigEngines.txt
      • fmeServerConfig.txt
      • fmeCommonConfig.txt
      • fmeWebSocketConfig.txt
    • FME Server Log Files
      • Message Logger Properties
    • API Quick-Find
    • FME Server Web Services
      • Transformation Services
      • Notification Service
      • OGC Services
      • Utility Services
      • Authentication and Authorization
    • FME Server Engines
      • Configuration File Layout
      • Pseudo Variables
      • Licensing the FME Engine
    • FME Server Core
      • Job Directives
      • Repositories
      • Resources
      • WebSocket Server
    • FME Server Process Monitor
    • FME Server Console
      • Starting the FME Server Console
      • Modes
      • Directives
      • Command Line Options
  • Web User Interface
    • FME Server Web Interface
    • Preparing to Use the Web Interface
    • Accessing the Web Interface
    • Account Management
      • Logging In to the Web Interfaces
      • Changing the Login Password
      • Logging Out
    • General Features
      • User Session Information
      • Server Information
      • About Times and Time Zones
    • Using the Interface
      • Run Workspace
      • Repositories
      • Projects
      • Schedules
      • Jobs
      • Dashboards
      • Notifications
      • Resources
      • Connections
      • Engines & Licensing
      • Security
      • System Cleanup
      • Backup & Restore
      • Services
      • CORS
  • All Files
      • Request and Install a License
      • Configuring the FME Engine
      • Working with the FME Server System Services
      • Purging Logs and History
      • Changing the Web Application Server Host Name and Port
      • Configuring International Character Encoding
      • Changing the File System to Another Machine
      • Configuring Native OGC Services Support
    • Notifications
You are here: Administrator's Guide > Other Common Tasks > Licensing and Administration Tasks
Configuring Implicit NAD27 to NAD83 Datum Shifts
Configuring Grid Transformation Definitions
Using Python with FME Server
Using R with FME Server
About the FME Server System Services
Starting and Stopping FME Server Manually
Determining FME Server Processes
Installing FME Server as a System Service (Linux)
