You are here: Reference Manual > FME Server Web Services > Notification Service > Working with JMS > Installing the JMS Libraries
An installation of FME Server includes the libraries that are required for using JMS messaging with Apache ActiveMQ 5.6.0. For all other message brokers, vendor-specific JMS libraries must be acquired and installed alongside FME Server.
Typically, vendor-specific JMS libraries are either available in the message broker’s installation, or available in a separate message broker client. In the case of IBM WebSphere MQ 7, for example, a separate client installation is available.
The table below provides links to appropriate software. For additional information, consult your vendor's documentation.
To install the JMS Libraries
  1. Download and install the software containing the vendor-specific JMS implementation library to the machine with the installation of FME Server.
  2. Locate the required libraries. (See the table below, under "Libraries.")
  3. Note the directory containing the required libraries. When Configuring FME Server as a JMS Client, this directory is added to the java classpath.
Message Broker Libraries Sample Path (Windows)
Apache ActiveMQ none (Apache ActiveMQ 5.6.0 libraries bundled with FME Server) --
IBM WebSphere 7.1
com.ibm.mq.jmqi.jar
com.ibm.mqjms.jar
dhbcore.jar
fscontext.jar
providerutil.jar
C:\Program Files (x86)\IBM\WebSphere MQ\java\lib
HornetQ
hornetq-jms.jar
hornetq-jms-client.jar
jnp-client.jar
C:\hornetq-x.y.z\lib
Oracle Weblogic wlthint3client.jar
What's Next?
Depending on your message broker, additional configuration may be required to enable JMS. See Configuring the JMS Provider
