You are here: Administrator's Guide > Installation Options > Distributed Installation > Installing for Active-Passive Failover > Database Configuration - Oracle
It is assumed that an Oracle database server is installed.
<FMEServerDir> is the installation directory of FME Server. In Windows, this is typically C:\Program Files\FMEServer.
If you are upgrading, you should back up any job history you want to keep.
Note: If your version of Oracle requires a service name, rather than session ID (SID), for database connections, you must update the DB_JDBC_URL parameter in configuration file fmeCommonConfig.txt accordingly. For more information, see this FME Knowledge Center article.
