The Scaler scales objects to make them bigger or smaller.
A separate multiplier must be set for each of the X, Y, and Z axes. For two-dimensional features, the Z multiplier is ignored.
If Text Scaling is set to "Location and Size", any text features will have their height scaled in addition to their location.
The value of Scale Origin specifies the location. The geometry is scaled relative to Scale Origin.
Specifies a component to scale on point cloud features. Note that the x, y, and z components can be scaled using the generic Scale Factors. This parameter is intended for non-spatial components (for example, intensity).
The multiplier that will be applied to the corresponding point cloud component.
Associated FME function or factory: @Scale
Tags Keywords: pointcloud
