Selects specific bands and palettes of a raster for subsequent transformer operations.
The bands and palettes are selected using the band and palette indices, specified in a string. The string may either be specified explicitly or through an attribute. The format of the string is B P (separated with a space), where B is the band index and P is the palette index of the band and palette to be operated on. Indices are zero-based, so the first band or palette is at index 0.
Choose whether the bands and palettes are specified explicitly in a band and palette list, or through an attribute.
The function will only accept alphanumeric characters and valid symbols in the code string. The code string accepts the symbols ",", ";", and ":".
Multiple palettes for a band can be specified, delimited by commas.
Multiple band-palette pairs can be specified delimited by semicolons.
The keyword ALL can be used in place of band and palette numbers to select all bands or all palettes on a certain band. Specific palettes cannot be selected on ALL bands.
Specify the attribute containing the band and palette list string.
| all bands | ALL |
| all bands and all palettes | ALL ALL |
| first palette of the first band of a raster | 0 0 |
| first palette of the first band and first palette of the third band | 0 0;2 0 |
| the first three bands of the raster (without their palettes) | 0;1;2 |
| the first three bands of the raster (with their palettes) | 0 ALL;1 ALL;2 ALL |
Associated FME function or factory: @SelectRaster
Tags Keywords: raster grid band channel palette lookup LUT colormap colourmap selection select modify
