Extracts the geometry properties of a raster feature and exposes them as attributes.
The following geometry properties are exposed:
_num_bands
_num_rows
_num_columns
_spacing_x
_spacing_y
_origin_x
_origin_y
_rotation_x
_rotation_y
_min_x
_min_y
_max_x
_max_y
_cell_origin_x
_cell_origin_y
_upper_left_x
_upper_left_y
_upper_right_x
_upper_right_y
_lower_right_x
_lower_right_y
_lower_left_x
_lower_left_y
None.
This transformer does not extract band or palette properties such as interpretation and nodata. To extract the band and palette properties of a raster, use the RasterBandPropertyExtractor.
Associated FME function or factory: @RasterProperties
Tags Keywords: raster grid band channel properties metadata expose extract rows columns width height extents origin spacing cell
