Extracts the band and palette properties of a raster feature and exposes them as attributes.
The following band and palette properties are exposed:
_band{}.band_name
_band{}.band_interpretation
_band{}.band_bit_depth
_band{}.band_interleaving
_band{}.band_num_tile_rows
_band{}.band_num_tile_columns
_band{}.band_nodata
_band{}.band_num_palettes
_band{}.palette{}.palette_name
_band{}.palette{}.palette_key_interpretation
_band{}.palette{}.palette_value_interpretation
_band{}.palette{}.palette_bit_depth
Wherever "{}" appears, there will be one instance of the attribute for each band or palette. The first will appear with {0}, the second with {1}, and so on.
Input features must contain raster geometries only.
None.
Associated FME function or factory: @RasterProperties
Tags Keywords: raster grid band channel palette lookup LUT colormap colourmap properties metadata expose extract interpretation nodata bitdepth tile
