Removes the selected palette(s) of a raster. The palette's band retains the palette key, but the corresponding values are lost.
If the source band has no palettes, the raster remains unchanged.
None.
This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
RasterPaletteResolver: Removes the palettes from selected bands, and resolves band cell values with the corresponding palette values.
Associated FME function or factory: @RemoveRasterPalettes
Tags Keywords: raster grid band channel palette lookup LUT colormap colourmap remove delete destroy
