Alters the underlying interpretation of the palettes of the raster geometry on the input features, using the specified conversion options.
For example, an input raster feature with a single band with a single palette of interpretation RGB24 could be converted to a single band with a single palette of RGB64 or String data.
Selects the destination interpretation along with the bit depth. Different interpretations allow for different conversion options to be used.
Selects the action to perform when converting an RGBA palette to an RGB palette. The Drop the alpha band option simply discards the alpha component from the palette. The Apply the alpha band option multiplies all RGB values with their corresponding, normalized alpha value.
Selects the action to perform when converting an RGB palette to an RGBA palette:
Selects the action to undertake when a conversion between different color types occurs.
Specifies the action to perform when converting from a floating-point value to an integer.
Each RasterPaletteInterpretationCoercer performs a conversion on the input raster. If multiple RasterPaletteInterpretationCoercers are used in sequence, then multiple conversions will take place; data quality and translation performance may suffer.
This transformer supports raster band and palette selection. The RasterSelector can be used to modify selection.
The RasterInterpretationCoercer performs similar operations on the raster as a whole, such as converting 4 bands directly to RGBA.
The RasterBandInterpretationCoercer performs similar conversions on individual bands.
This transformer replaces the RasterDataTypeCoercer and RasterColorModelCoercer transformers.
Associated FME function or factory: @ReinterpretRaster
Tags Keywords: raster grid band channel palette lookup LUT colormap colourmap datatype convert coerce adjust interpretation colormodel colourmodel bitdepth rescale scale
