RasterBandNodataSetter
Identifies a value to act as a nodata identifier on a raster feature at the band level. That is, values equal to the specified value will now be considered invalid, and will not be affected by many operations (for example, offsetting or scaling).
All selected bands on an input raster feature will receive the same specified nodata value.
Transformer Categories
Rasters
FME Licensing Level
Technical History
Associated FME function or factory: @RasterNodata
Search FME Knowledge Center
Tags Keywords: raster grid band channel palette key lookup LUT colormap colourmap nodata null void value set modify flag
