Extracts point orientation to feature attributes.
Features with point geometries.
Features with newly set attributes based on point orientation. No attributes are added to features containing points with no orientation.
Specifies the representation to use when extracting point orientation. The following representations are supported:
Name of the attribute on which to store 2D rotation.
Name of the attribute on which to store the X component of the normal.
Name of the attribute on which to store the Y component of the normal.
Name of the attribute on which to store the Z component of the normal.
Name of the attribute on which to store spin.
Name of the attribute on which to store the X component of the axis.
Name of the attribute on which to store the Y component of the axis.
Name of the attribute on which to store the Z component of the axis.
Name of the attribute on which to store the degrees of rotation around the axis (right hand rule).
Name of the attribute on which to store azimuth.
Name of the attribute on which to store altitude.
Name of the attributes on which to store the coefficients of the transformation matrix:
x' = Ax + By + Cz
y' = Dx + Ey + Fz
z' = Gx + Hy + Iz
Name of the attribute on which to store the x coefficient.
Name of the attribute on which to store the y coefficient.
Name of the attribute on which to store the z coefficient.
Name of the attribute on which to store the w coefficient.
Name of the attribute on which to store the first rotation, around the Z-axis.
Name of the attribute on which to store the second rotation, around the X’-axis.
Name of the attribute on which to store the third rotation, around the Z’’-axis.
Name of the attribute on which to store yaw.
Name of the attribute on which to store pitch.
Name of the attribute on which to store roll.
