Accesses the Dropbox file storage service to upload, download, or delete files and folders or list the contents of a folder from a Dropbox account.
Depending on your choice of actions, it will upload or download files, folders, and attributes; list information from the service; or delete items from the service. On uploads, link attributes are added to the output features. On List actions, file/folder information is added as attributes.
In this example, the DropboxConnector is used to download an Autodesk AutoCAD DWG file from Dropbox. After creating a valid web connection to a Dropbox account (which can be done right in the Dropbox Account parameter), the path and filename to download both from and to are entered.
s
A FeatureReader is added to read the newly downloaded dataset. Here, the ParcelLines feature type will be further processed elsewhere in the workspace.
By executing the download here in the workspace, the source dataset will be refreshed every time the workspace is run.
In this example portion of a workspace, the DropboxConnector is used to download a raster orthoimage from Dropbox into an attribute.
The file is read from Dropbox, and the contents stored as a blob attribute. Then a RasterReplacer is used to interpret the blob into a usable raster format.
The combination of these two transformers avoids having to download the image to local storage and re-read it. A similar technique can be used for point cloud files, using the PointCloudReplacer transformer.
This transformer cannot be used to directly move or copy files between different Dropbox locations. However, multiple DropboxConnectors can be used to accomplish these tasks.
The output of this transformer will vary depending on the Dropbox Action performed.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Dropbox Action |
The type of operation to perform. Choices include:
Dropbox Account |
Performing operations against a Dropbox account requires the use of OAuth2 authentication using a Web Connection. To create a Dropbox connection, click the 'Dropbox Account' drop-down box and select 'Add Web Connection...'. The connection can then be managed via Tools -> FME Options... -> Web Connections. |
The remaining parameters available depend on the value of the Request > Dropbox Action parameter. Parameters for each Dropbox Action are detailed below.
Delete File at Path |
Path to a file/folder on Dropbox to delete. |
Deleted File Count |
Specify the attribute that will store a count of the number of files/folders that were deleted. |
Download File at Path |
The Dropbox path to the file to download. |
Download as |
Select whether to store the downloaded data in a File or Attribute.
Download to File | Specify the path to the file that will store the downloaded file. |
Download to Attribute | Specify the attribute that will store the contents of the downloaded file. Valid for Download as Attribute only. |
List Contents at Path |
The path on Dropbox to list the contents of. |
Default attribute names are provided, and may be overwritten.
File or Folder Name |
Specify the attribute to hold the name of an object on Dropbox. |
Full Path |
Specify the attribute to hold the full path of an object on Dropbox. |
File Size |
Specify the attribute to hold the size of a file object on Dropbox. |
Revision | Specify the attribute to hold the revision string of an object on Dropbox. |
Last Modified |
Specify the attribute to hold the last modified date of an object on Dropbox. |
File or Folder Flag |
Specify the attribute to hold the type (file or folder) of an object on Dropbox. |
Upload from |
The type of data to be uploaded.
When working with large objects, File is a better choice than Attribute Content as the data will be streamed directly from disk and not require that the object be stored entirely in memory on a feature. |
File to Upload |
The file to be uploaded to Dropbox if Upload from is set to File. |
Source Folder |
The folder to be uploaded to Dropbox if Upload from is set to Folder. |
Include Subfolders |
Choose whether to upload subfolders of the Source Folder or not. |
Attribute to Upload as File |
The data to be uploaded, supplied from an attribute if Upload from is set to Attribute Content. |
Data Encoding | The encoding type of Attribute to Upload as File. |
Upload to Path | The path on Dropbox to upload the source file to. To upload to the root directory, enter “/”. |
Upload with File Name | The name of the file created from the data supplied in Attribute to Upload as File. The name must include a filename extension (for example, .txt, .jpg, .doc). |
Shared Link |
Specify the output attribute that will store a temporary publicly accessible URL that links to the file on Dropbox. |
Direct Download Link |
Specify the output attribute that will store a URL that links to the file on Dropbox. The URL can only be used by authenticated users. |
A set of control characters is available in the Text Editor. | |
Working with User Parameters | Create your own editable parameters. |
Dependencies | Dropbox account |
FME Licensing Level | FME Professional Edition and above |
Aliases | DropboxCaller |
History | |
Categories |
Search for all results about the DropboxConnector on the FME Knowledge Center.
