PointCloudReplacer
Replaces the geometry of the feature with the geometry held in the Blob Attribute. The blob is decoded according to the selected point cloud format.
Note that this transformer only works with point cloud formats. Use the GeometryReplacer for vector formats or the RasterReplacer for raster formats.
Currently supported formats include:
Related Transformers
This transformer is typically used to restore a point cloud previously extracted into an attribute by the PointCloudExtractor.
GeometryExtractor
GeometryReplacer
RasterExtractor
RasterReplacer
Transformer Categories
Point Clouds
FME Licensing Level
Technical History
FME Factory Used: @GeometryFormat
Search FME Knowledge Center
Tags Keywords: geometry database extract replace blob serialize
