You are here: New Formats for 2017 > OpenStreetMap (OSM) Protocolbuffer Binary Format (PBF) Reader > Quick Facts
                                             OpenStreetMap (OSM) Protocolbuffer Binary Format (PBF) Quick Facts
                                                         Format Type Identifier  |
                                                         OSMPBF  |
                                                         Reader/Writer  |
                                                         Reader  |
                                                         Licensing Level  |
                                                         Professional and above  |
                                                         Dependencies  |
                                                         None  |
                                                         Dataset Type  |
                                                         File  |
                                                         Feature Type  |
                                                         Element Type  |
                                                         Typical File Extensions  |
                                                         .osm.pbf  |
                                                         Automated Translation Support  |
                                                         Yes  |
                                                         User-Defined Attributes  |
                                                         No  |
                                                         Coordinate System Support  |
                                                         Yes  |
                                                         Generic Color Support  |
                                                         No  |
                                                         Spatial Index  |
                                                         No  |
                                                         Schema Required  |
                                                         Yes  |
                                                         Transaction Support  |
                                                         No  |
| Encoding Support | Yes |
                                                         Geometry Type  |
                                                         osmpbf_type  |
OSMPBF Geometry Support
                                                         Geometry  |
                                                         Supported?  |
                                                         aggregate  |
                                                         yes  |
                                                         circles  |
                                                         no  |
                                                         circular arc  |
                                                         no  |
                                                         donut polygon  |
                                                         yes  |
                                                         elliptical arc  |
                                                         no  |
                                                         ellipses  |
                                                         no  |
                                                         line  |
                                                         yes  |
                                                         none  |
                                                         no  |
                                                         point  |
                                                         yes  |
                                                         polygon  |
                                                         yes  |
                                                         raster  |
                                                         no  |
                                                         solid  |
                                                         no  |
                                                         surface  |
                                                         no  |
                                                         text  |
                                                         no  |
                                                         z values  |
                                                         no  |
