OpenStreetMap (OSM) Protocolbuffer Binary Format (PBF) Feature Representation
Features read from OSMPBF file consist of geometry and a series of attribute values. The attribute names are as defined in the workspace. Features being returned may include additional attributes that do not appear on the reader schema, since each OSM element can include an arbitrary set of OSM tags. OSMPBF attribute values are stored in UTF-8 encoding.
In addition to the generic FME feature attributes that FME Workbench adds to all features (see About Feature Type Attributes), this format adds the format-specific attributes described in this topic.
Attribute Name |
Contents |
| osmpbf_changeset | The 32-bit integer identifier of the last OSM changeset that included modifications to the element. |
| osmpbf_id |
The 64-bit integer identifier for the OSM element. IDs are unique within each element type. Therefore there will be no two “node” features with the same ID; however, a “node” feature may have the same ID as a “way” feature. |
| osmpbf_timestamp |
The time at which the OSM element was last modified. Timestamps are converted to FME datetime string format. YYYYMMDDHHmmSS (Year, Month, Day, Hour, Minute, Second) If a timezone is specified, then the offset from GMT is included at the end of the string in the format: [+/-]HH:mm (Plus or Minus, Hour, Minute) |
| osmpbf_type | The type of geometric entity stored within the feature. The valid values are detailed in the Geometry table below. |
| osmpbf_uid |
The 32-bit integer identifier of the OSM user who last modified the element. |
| osmpbf_user | The username of the OSM user who last modified the element. |
| osmpbf_version |
The 32-bit integer version number of the OSM element. This number represents the number of times the element has been modified. |
Geometry
osmpbf_type |
Description |
| osmpbf_node |
Point feature |
| osmpbf_way |
Linear feature |
osmpbf_area |
Simple polygon or donut feature |
| osmpbf_relation |
Feature with multiple geometries |
Attribute Type Mapping
OSMPBF Attribute Type |
FME Attribute Type |
| string | fme_buffer |
| string | fme_varchar(width) |
| string | fme_char(width) |
| string | fme_xml |
| string | fme_json |
| string | fme_binarybuffer |
| string | fme_binary(width) |
| string | fme_varbinary(width) |
| datetime | fme_datetime |
| datetime | fme_date |
| datetime | fme_time |
| double | fme_real64 |
| double | fme_real32 |
| double | fme_decimal(width, precision) |
| string | fme_uint64 |
| int64 | fme_int64 |
| int64 | fme_uint32 |
| int32 | fme_int32 |
| int32 | fme_unt16 |
| int32 | fme_int16 |
| int32 | fme_uint8 |
| int32 | fme_int8 |
| string | fme_boolean |
