You are here: Popular Formats > Esri Geodatabase Reader/Writer > Geodatabase Quick Facts
About Quick Facts Tables
Format Type Identifier
  • GEODATABASE_SDE – Esri Geodatabase (ArcSDE Geodb)
  • GEODATABASE_MDB – Esri Geodatabase (Personal Geodb)
  • GEODATABASE_FILE – Esri Geodatabase (File Geodb ArcObjects)
  • GEODATABASE_SDE_RASTER_DATASET – Esri Geodatabase (ArcSDE Geodb Raster Dataset)
  • GEODATABASE_FILE_RASTER_DATASET – Esri Geodatabase (File Geodb Raster Dataset)
  • GEODATABASE_SDE_RASTER_CATALOG – Esri Geodatabase (ArcSDE Geodb Raster Catalog)
  • GEODATABASE_FILE_RASTER_CATALOG – Esri Geodatabase (File Geodb Raster Catalog)
  • Esri Geodatabase (ArcSDE Geodb Raster Catalog): Esri Edition
Reader/Writer
Both
Licensing Level
  • Esri Geodatabase (File Geodb ArcObjects): Base Edition
  • Esri Geodatabase (File Geodb Raster Dataset): Professional Edition
  • Esri Geodatabase (File Geodb Raster Catalog): Base Edition
  • Esri Geodatabase (Personal Geodb): Base Edition
  • Esri Geodatabase (ArcSDE Geodb): Esri Edition
  • Esri Geodatabase (ArcSDE Geodb Raster Dataset): Esri Edition
Dependencies
  • Esri ArcGIS Desktop (32-bit Geodatabase)
  • Esri ArcGIS Server 10.1 or newer (64-bit Geodatabase)
Dataset Type
  • None (ArcSDE)
  • File (Access)
  • Folder (File-based)
Feature Type
Feature Class name
Typical File Extensions
for Personal Geodatabase: .mdb , .accdb
Automated Translation Support
Yes
User-Defined Attributes
Yes
Coordinate System Support
Yes
Generic Color Support
No
Appearance Support (Surfaces Only) Yes
Spatial Index
Always
Schema Required
Yes
Transaction Support
Yes
Geometry Type
geodb_type
Encoding Support
Yes
Geodatabase Geometry Support
Geometry Supported?
aggregate
yes
circles
yes
circular arc
yes
donut polygon
yes
elliptical arc
yes
ellipses
yes
line
yes
none
yes
point
yes
polygon
yes
raster
yes
solid
yes
surface
yes
text
yes
z values
yes
Geodatabase Raster-Specific Quick Facts
Band Interpretations Red8, Red16, Green8, Green16, Blue8, Blue16, Gray8, Gray16, Int8, UInt8, Int16, UInt16, Int32, UInt32, Real32, Real64
Palette Key Interpretations UInt8, UInt16
Palette Value Interpretations RGB24
Nodata Value Yes
Cell Origin (x, y) 0.5, 0.5
Rotation Support No
GCP Support No
World File Support No
TAB File Support No
Note: Esri Geodatabases can store rasters as raster datasets, raster catalogs, and raster mosaics. FME supports reading raster datasets and raster catalogs. In addition, FME supports reading mosaic datasets either as a single mosaicked raster through a raster dataset reader, or as multiple-source rasters through a raster catalog reader. Writing is supported for raster datasets but not for raster catalogs or mosaic datasets. Finally, raster support is limited to File Geodatabases and Enterprise Geodatabases.
