You are here: Popular Formats > Esri Geodatabase Reader/Writer > Writer Workbench Parameters > Esri Geodatabase (ArcSDE Geodb) Writer Parameters
Database Connection
General Parameters
Table Parameters
Writer Parameters and Feature Type Parameters
The values populated in the parameters dialog set the values both for writer parameters and for feature type parameters. Since some feature type parameters have equivalent writer-level parameters, the parameter value may be used in two places.
Feature type parameters take precedence over writer parameters. The only time the writer-level parameters will be used is when there is no equivalent feature type parameter, or the parameter was not supplied.
