Menu Commands and Shortcuts
See also Workbench Keyboard Shortcuts for an additional list of shortcuts.
File
| Command | Keyboard Shortcut | Function |
| New | Ctrl+n | Opens the Create Workspace dialog, which provides different options for creating a new workspace. |
| Open | Ctrl+o | Opens a file browser so you can pick an FME workspace (.fmw) file. |
| Generate Workspace | Ctrl+g | Opens the Generate Workspace dialog. |
| Open Recent/Open Recent Template | Opens a recently-opened workspace or workspace template. | |
| Close | Ctrl+w | Closes the current workspace. |
| Save | Ctrl+s | Saves the current workspace. |
| Save As | Saves the current workspace to a different name. You can also save a simple workspace to a mapping file (.fme) for use with the FME Quick Translator. |
| Save As Template | Saves the current workspace as a template (.fmwt). | |
| Export as Custom Transformer | Exports the workspace as a custom transformer. | |
| Export As Custom Format | Exports the workspace as a custom transformer. | |
| Publish/Republish to FME Server | Publishes a workspace to an FME Server. Note that you must have an FME Server configured as part of your system. | |
| Download from FME Server | Downloads a workspace from an FME Server. Note that you must have an FME Server configured as part of your system. | |
| Page Setup | Sets page layout for print. | |
| Print/Print Preview | Prints the workspace. See also View > Page Breaks. | |
| Send To | Opens your e-mail client with the current workspace attached to a new e-mail. | |
| Exit | Ctrl+q | Quits Workbench. |
Edit
| Undo | Ctrl+z | Reverses the most recent action in a workspace. |
| Redo | Ctrl+y | Repeats the most recent action that you reversed in a workspace. |
| Cut | Ctrl+x | Cuts a selection and sends it to the clipboard. |
| Copy | Ctrl+c | Copies a selection and sends it to the clipboard. |
| Paste | Ctrl+v | Pastes a selection from the clipboard. |
| Delete | Del (key) | Deletes a selection. |
| Bring to Front/Send to Back | Brings objects forward on the canvas or sends them behind other objects. | |
| Align Horizontally/Vertically | Aligns selected objects on the canvas with one another, according to the specified orientation. | |
| Spread | Evenly spaces selected objects on the canvas from one another, either horizontally vertically. | |
| Select All | Ctrl+a | Selects all content on the canvas. |
View
| Windows | Shows/hides various Workbench windows. | |
| Expand All/Collapse All | Expands/collapses all workspace objects. | |
| View Attached Annotations | Shows/hides annotations defined by the user. | |
| View Summary Annotations | Shows/hides summary annotations, which display a box that contains information about the feature type or transformer. | |
| Zoom |
Sets default zoom properties. Locate the corresponding tool Zoom Mini-bar in FME > Options > Toolbar.
The tool has a slider, +/- buttons, and a text entry box so you can enter a zoom value. It also includes a "zoom to extents" button to fit the workspace into the available canvas area. |
Tags grids |
Displays the Grid and Guides dialog:
| Maximize Canvas | Shift+F11 | Maximizes the canvas to the size of the current window. |
| Full Screen | F11 | Maximizes the canvas to the size of the screen. |
Readers
| Add Reader | Ctrl+Alt+r | Adds a reader to the workspace. |
| Import Feature Types | Imports feature types from a different dataset. | |
| Update Feature Types |
Updates feature types if the structure of the data has changed outside the workspace. |
| Enable/Disable Feature Types | Temporarily disables (or enables) feature types in the workspace. | |
| Remove Feature Types | Removes the specified feature types. | |
| Remove Readers | Removes the specified readers. | |
| Add Reader as Resource | Inserts a reference to a dataset to be used in the workspace. |
Transformers
| Add Transformer | / (key) | Opens a search bar for adding a transformer to the canvas. |
| Remove Transformers | Removes the specified transformers from the workspace. | |
| Enable/Disable Transformers | Disables (or enables) transformers in the workspace. | |
| Enable/Disable Inspectors | Disables (or enables) any Inspectors in the workspace. | |
| Create Custom Transformer | Ctrl+t | Adds a custom transformer to the workspace. |
| Embed All Transformers | Changes the status of any linked custom transformers in the workspace to embedded. |
Writers
| Add Writer | Ctrl+Alt+w | Adds a writer to the workspace. |
| Add Feature Type | Adds a new feature type to the workspace. | |
| Import Feature Type | Imports a feature type from a different dataset. | |
| Update Feature Types | Updates feature types if the structure of the data has changed outside the workspace. | |
| Remove Feature Types | Removes a feature type. | |
| Remove Writers | Removes the specified writer. | |
| Move Feature Types | Moves feature types between datasets. | |
| Redirect to FME Data Inspector | Redirects the output to the FME Data Inspector. |
Run
| Run Workspace | F5 | Runs the workspace with existing parameters. |
| Run With Prompt | Ctrl+r | Runs the workspace and prompts you to change parameters (for example, if you want to use different source data). |
| Run With Full Inspection | Shift+F5 | Runs the workspace in inspection mode. All links and ports display feature counts. |
| Run With Breakpoints | Ctrl+Shift+F5 | Runs the translation using the Feature Inspector, after you define a breakpoint. |
| Batch Deploy | Runs the translation in batch mode. |
Tools
| Remove Unattached | Removes any unattached objects from the workspace. | |
| Edit Parameters | Displays all reader and writer parameters in a dialog. This is useful especially if you have a large workspace or multiple readers/writers. | |
| Edit Header | Allows you to add format directives into the workspace (Advanced user task) | |
| Purge Temporary Files | Purge temporary Workbench-related files. | |
| Browse Coordinate Systems | Opens the Coordinate System Gallery. | |
| Browse Geographic Transformations | Opens the Geographic Transformation Gallery. | |
| Browse Readers and Writers | Opens the Reader and Writer (supported formats) Gallery. | |
| License Borrowing | Allows floating license holders to temporarily use another floating license. | |
| FME Options | Sets default options. |
