Printing Workspaces
File > Page Setup
- Paper Size/Source: Choose from standard page sizes and paper sources.
- Orientation: Portrait or Landscape
- Margins: Set margins in millimeters. The default is 10 mm from each edge of the page.
- Scale: Choose to always fit the workspace on a page, or always scale to a certain percentage.
- Decorations: Check this box to include file-type information, page number and corner borders on the printout.
File > Print Preview
Select to preview a topic before you print. You can also print directly from this window.
File > Print
Bypass preview mode.
