SQLite Non-Spatial Reader Parameters
Database Connection
Enter the file name of the SQLite3 database.
Constraints
Click the Browse button and choose from the list of feature types.
Schema Attributes
- In a non-dynamic scenario where you have multiple feature types, it is convenient to expose additional attributes using this one parameter. For example, if you have ten feature types and want to expose the same attribute in each one, it is easier to define it once than it is to set each feature type individually in the workspace.
