Oracle Spatial Object Reader Feature Type Properties: Format Parameters
To access feature type format parameters, open the Feature Type Properties dialog by clicking the properties button on a feature type in the workspace.
These parameters apply only to a selected feature type, not to the entire reader.
Note: If a feature type parameter corresponds to a reader-level parameter, then the reader parameter will be ignored and the feature type parameter will be used.
Table Settings: Spatial
The name of the column containing geometry, when reading from only one of multiple geometry columns. When not specified, the first geometry column found is chosen.
These parameters specify the spatial extent of the features to be read from the layer.
If these parameters are not all specified, the values from the Reader Parameters are used.
Table Settings: MapInfo Symbology
This parameter specifies the name of the column which contains style information for MapInfo symbology.
When set, the feature read will contain a set of MIF format attributes and FME generic attributes which correspond to the symbology information parsed from this field. If this parameter is not set, no symbology is read.
