• Workbench Format Resources
    • Copyright and Trademark Information
    • FME Terminology
    • Feature Type Properties
    • Using Database Connections
    • Feature Operations
    • Using Web Service Connections
    • FME Geometry Model
    • Standard FME Date and Time Format
  • All Formats
    • List of Supported Formats
  • Popular Formats
    • Quick Facts: Popular Formats
    • Bentley MicroStation Design Reader/Writer
    • Autodesk AutoCAD DWG/DXF Reader/Writer
    • CSV (Comma-Separated Value) Reader/Writer
    • Esri Shapefile Reader/Writer
    • Esri Geodatabase Reader/Writer
    • FME Feature Store Reader/Writer
    • Google KML Reader/Writer
    • MapInfo TAB (MAPINFO/MITAB) Reader/Writer
    • Microsoft Excel (XLSXR/XLSXW) Reader/Writer
    • TIFF (Tagged Image File Format) Reader/Writer
    • XML (Extensible Markup Language) Reader/Writer
  • New Formats for 2016+
    • Autodesk ReCap Writer
    • Autodesk FBX Reader
    • Elastic Elasticsearch Reader/Writer
    • Cesium 3D Point Cloud Reader/Writer
    • Denodo Reader
    • Esri ArcGIS Portal Feature Service Reader/Writer
    • FME Workspace Reader
    • General Transit Feed Specification (GTFS) Reader/Writer
    • HTML Writer
    • IndoorGML Reader/Writer
    • IBM Cloudant Reader/Writer
    • IBM DB2 Non-Spatial (JDBC) Reader/Writer
    • IBM Informix Non-Spatial (JDBC) Reader/Writer
    • Microsoft Access JDBC Reader/Writer
    • Microsoft Azure DocumentDB Reader/Writer
    • Microsoft SQL Server and Azure SQL Database Non-Spatial (JDBC) Reader/Writer
    • Microsoft SQL Server and Azure SQL Database Spatial (JDBC) Reader/Writer
    • SAP HANA Non-Spatial Reader/Writer
    • Sentinel-1 SAR SAFE Raster Reader
    • SAP Sybase Adaptive Server Enterprise (ASE) Reader/Writer
    • Sentinel-2 MSI SAFE Raster Reader
    • Tableau Data Extract (TDE) Writer
  • All Files
Search the Online Transformer Gallery
    • Quick Facts
    • Reader Parameters
    • Writer Parameters
    • Writer Feature Type Properties
      • User Attributes
      • Format Parameters
    • Feature Representation
You are here: New Formats for 2016+Microsoft SQL Server and Azure SQL Database Non-Spatial (JDBC) Reader/WriterFeature Representation
Feature types correspond to the database table with the same name, and attributes correspond to columns of the same name.
