Microsoft Access Writer Parameters
Database Connection
The password to access the database.
For existing databases, it may be omitted for Access databases without password protection.
If the database does not exist, then the newly created Microsoft Access database will be protected by this password.
Tells the Microsoft Access writer what version of database should be created. If the database file already exists, the writer will automatically detect and use the correct version.
If checked, the writer deletes the existing database before writing.
If a template file is specified, the destination file is replaced with a copy of the template before writing begins.
