You are here: Popular FormatsBentley MicroStation Design Reader/WriterFeature RepresentationAttribute LinkagesAttribute Lists – incosada linkage
If the linkage is an incosada type, then the following attribute names are added by the reader to hold the values for the British Columbia Forestry File (INCOSADA) linkage. Note that INCOSADA linkages are not supported in Version 8 DGN files, nor are they supported by the Design file writer.
Linkage Parameter |
Contents |
incosada_fid |
The unique feature ID of the linkage. Range: Character string of size 32 consisting of hex digits |
incosada_sequence_num |
Sequence number of the linkage. Range: integer |
incosada_feature_code |
The feature code of the INCOSADA feature Range: unsigned 32-bit integer |
