You are here: Popular FormatsBentley MicroStation Design Reader/WriterFeature Representation3D Solids
3D Solids
igds_type: igds_3d_solid
This is supported for v8 only. This element should not be confused with igds_solid as it correspond to IGDS element type 19 (not to unnamed cell).
FME supports both reading and writing; however, support is currently limited to only extrusions. Work to add support for other solid types is currently underway.
