Esri Geodatabase (XML Workspace Document) Reader
Note: To use FME’s Esri XML Workspace Document (ArcObjects) Reader, you must also install Esri ArcGIS® 9 or newer.
This reader is based on the same technology as FME’s Esri Geodatabase Reader. The two formats are essentially the same.
Note: Please see the Reader section of the Esri Geodatabase Reader/Writer for information on usage. Only the Geodatabase Reader directives listed in that chapter are currently supported.
Overview
The XML Workspace Document (ArcObjects) Reader was previously named ESRI Geodatabase (XML) Reader.
This format enables FME to retrieve data from ESRI’s XML Workspace Document. It can read both binary and text XML Workspace Documents.
