Microsoft Windows Azure Table Reader Parameters
Connection Parameters
The service name for accessing the Windows Azure storage account that contains the tables to be read. For example, http://<storage service>.cloudapp.net.
Specifies the primary access key for accessing the Microsoft Windows Azure Storage service.
Table Name
Specifies the name of the table to read data from. The table name can be entered manually or chosen from a list of tables accessible by the account specified by the Storage Service Name.
Schema Attributes
- In a non-dynamic scenario where you have multiple feature types, it is convenient to expose additional attributes using this one parameter. For example, if you have ten feature types and want to expose the same attribute in each one, it is easier to define it once than it is to set each feature type individually in the workspace.
