Feature Representation
In addition to the generic FME feature attributes that FME Workbench adds to all features (see About Feature Attributes), this format adds the format-specific attributes described in this topic.
ArcGIS Image Server features specify a matrix of x, y, and z coordinates. For each raster, there will only be a single feature returned.
Attribute Name |
Contents |
arcgis_image_server_type |
This will always be arcgis_image_server_raster. |
arcgis_image_server_service_ |
The image service reference file path or the url path. |
The title given to the image service. This is generally different but related to the name. |
The edition of the image service similar to a version number. |
A unique ID for the image service and version number. If the image service is changed, this value should also be changed. It may be used to track the lineage of an image service. |
A geographic region, such as town, state, or country. |
A description of the pixel values. The default list provides some examples, including True Color;False Color; NDVI Legend;Radiance;Elevation m; and Elevation ft. Other values can exist. |
A description of the source from which the pixel values are obtained. This is generally the sensor type or original source. The default list provides some examples, including Aerial Photography; Landsat; QuickBird; Scanned Maps; SRTM; and Mixed. Other values can exist. |
A summary of the processing applied by the image service to the raw imagery. |
The originator of the image service. |
The publisher of the image service. |
arcgis_image_server_service_rights |
The owner or owners of the rights to the data and image service. |
The contact organization for the image service. |
The contact person for the image service. |
The date of the first image added in the image service. |
The date of the last image added in the image service. |
arcgis_image_server_service_ creation_date |
The date the image service was created. |
The time the image service was created. |
The date the image service was last modified. |
The time the image service was last modified. |
The abstract of the image service. |
arcgis_image_server_service_purpose |
The purpose of the image service. |
arcgis_image_server_version |
The version number of the ArcGIS Image Server in the dataset. |
