KML Writer Feature Type Properties: Format Parameters
To access feature type format parameters, open the Feature Type Properties dialog by clicking the properties
button on a feature type in the workspace.
These parameters apply only to a selected feature type, not to the entire writer.
Tip: If a feature type parameter listed here conflicts with a writer-level parameter, then the writer parameter will be ignored and this feature type parameter will be used.
Specifies the icon to use for information point icons for the current feature. Click the browse button beside the parameter field to view the available icons.
You can also enter a value that is either the full path to an icon, or the name of an icon in $(FME_HOME)/icons.
If no value is specified, the information point icon will not be created.
Specifies the color for each information point icon.
Valid values are any fme color specification.
For more information, see Controlling Features with Format Attributes.
Specifies the fill color.
Specifies the fill opacity. Valid values are 0 to 1.
Specifies the pen color.
Valid values: Any fme color specification.
Specifies the pen opacity.
Valid values: 0 to 1.
The name of the attribute that will be used to sort features within the folder that corresponds to the feature type. Only applies to user-defined feature types.
If unspecified, the order of the features will be in the original arrival order.
Specifies whether or not the description, snippet, and balloon text elements should be wrapped in a CDATA block.
Values: Yes | No
Default: Yes
Determines whether or not user-defined attributes will be included in the feature’s description field. The value of the Use HTML Description Fields parameter will determine if the attributes, and their corresponding values, will be displayed using a HTML table, or a series of colon-separated key-value pairs.
Values: Yes | No
Default: Yes
This parameter specifies an alternative filename for the root document if the dataset is either a KMZ file or a folder. Use of this parameter may result in a dataset that is unreadable by Google Earth.
