You are here: LicensingFloating LicensesTroubleshooting Floating LicencesSystem error 1067 has occurred
Symptoms
The following error occurs following an attempt to start the license server:
system error 1067 has occurred
Cause
This error can occur if you were provided an invalid license file.
Resolution
Open the safe.lic file that you saved to your FlexServer directory. (For example: C:\Program Files\FlexServer\
.) It should contain a number of lines starting with 'FEATURE'.
If the file only has the following contents, then it is invalid:
SERVER 0022fb821528 skyfire
VENDOR safe
USE_SERVER
Send your hostid.txt (Start > Programs > FlexNet for Safe Software > View hostid.txt) and safe.lic files to codes@safe.com and mention that the license file is empty. A new license file will be generated for you.
