You are here: LicensingFloating LicensesTroubleshooting Floating LicencesThe License Server will not Start on Linux
The FlexNet license server fails on Linux
Symptoms
On the client machine, the error message is:
....License system failure. Check that the safe daemon version is newer than the FME client version. Program Terminating.
On the license server, the error message is:
./lmgrd -c ./safe.lic -l safe.log
>-bash: ./lmgrd: No such file or directory
Cause
FlexNet is missing necessary libraries to run on Linux
Resolution
On the license server, install lsb-coreby typing the following command in the Linux terminal:
sudo apt-get install lsb-core
