Custom Transformer Parameters
Parameter | Description | ||||||||||||
Password | If a custom transformer is exported, it can be password-protected. | ||||||||||||
Transformer Insert Mode | Determines how the transformer is referenced in workspaces. May depend on whether the transformer is exported or not. | ||||||||||||
Deprecated | If Yes, the transformer is no longer available for use in newly-created workspaces. It remains usable only in existing workspaces. | ||||||||||||
Check for missing attribute references | If Yes, the transformer returns a warning if an attribute is not present on the features entering the transformer. See Check for Missing Attribute References. | ||||||||||||
Enable Blocked Looping |
If Yes, the transformer can bypass its blocking behavior when used in a loop, and the following additional parameters apply:
For more information, see Looping with a Blocking Transformer. |
Parallel Processing Level |
Specifies the number of threads the custom transformer can process in parallel.
For more information, see "About Parallel Processing" in the FME Transformers Help. |
Parallel Process By | Specifies an attribute or parameter by which to group parallel processing threads. For example, if the attribute 'STATE' is specified, the transformer processes each state in parallel. | ||||||||||||
Parallel Process Groups are Ordered | If Yes, the FME engine can assume that data is inputted to the custom transformer in order for each 'Parallel Process By' parameter value. This setting provides a performance and memory boost, because the engine does not need to wait for all features to arrive before beginning a process. Set this value to Yes only if the structure of your dataset allows for data throughput in order by the 'Parallel Process By' setting. |
