Precisely MapInfo Extended TAB Writer Parameters
Writer
By default, the writer will produce NativeX tables but you can choose to write older Native tables.
File Contents
This parameter is applicable if you are working with extended (not basic ASCII) character sets. If your source data contains non-ASCII characters, using this parameter along with the encoding value ensures that the original data is preserved from the reader to the writer.
By default, the writer produces UTF-16 encoded documents. If you select any other character encoding, it will take precedence over the default.
FME supports most encodings.
Spatial
Coordinate systems may be extracted from input feature data sources, may come predefined with FME, or may be user-defined. FME allows different output and input coordinate systems, and performs the required coordinate conversions when necessary.
If a coordinate system is specified in both the source format and the workspace, the coordinate system in the workspace is used. The coordinate system specified in the source format is not used, and a warning is logged. If a source coordinate system is not specified in the workspace and the format or system does not store coordinate system information, then the coordinate system is not set for the features that are read.
If a destination coordinate system is set and the feature has been tagged with a coordinate system, then a coordinate system conversion is performed to put the feature into the destination system. This happens right before the feature enters into the writer.
If the destination coordinate system was not set, then the features are written out in their original coordinate system.
If a destination coordinate system is set, but the source coordinate system was not specified in the workspace or stored in the source format, then no conversion is performed. The features are simply tagged with the output system name before being written to the output dataset.
For systems that know their coordinate system, the Coordinate System field will display Read from Source and FME will read the coordinate system from the source dataset. For most other input sources, the field will display Unknown (which simply means that FME will use default values). In most cases, the default value is all you'll need to perform the translation.
You can always choose to override the defaults and choose a new coordinate system. Select More Coordinate Systems from the drop-down menu to open the Coordinate System Gallery.
Changing a Reprojection
To perform a reprojection, FME typically uses the CS-MAP reprojection engine, which includes definitions for thousands of coordinate systems, with a large variety of projections, datums, ellipsoids, and units. However, GIS applications have slightly different algorithms for reprojecting data between different coordinate systems. To ensure that the data FME writes matches exactly to your existing data, you can use the reprojection engine from a different application.
To change the reprojection engine, Select Workspace Parameters > Spatial > Reprojection Engine. In the example shown, you can select Esri (but the selection here depends on your installed applications):
- The coordinate systems file coordsys.db in the FME installation folder contains the names and descriptions of all predefined coordinate systems.
- Some users may wish to use coordinate systems that do not ship with FME, and in those cases, FME also supports custom coordinate systems.
- Learn more about Working with Coordinate Systems in FME.
Explicit Coordinate System Line
The coordinate system string that should be used in the output files.
Usually, FME examines the coordinate system information present on the features written to the files, and outputs the coordinate system based on this information. However, in certain circumstances it is necessary to override this and force a particular coordinate system to be output. This is typically done to force the units of a non-Earth projection to something other than the default, which is meters.
Allows explicit setting of the bounds of the output features.
If the custom coordinate system string is specified and already contains bounds, those will be used. If the string is missing bounds, the specified bounds (Min X, Min Y and Max X, Max Y) will be used instead.
