User linkages with a userId of 2570, 22244, 32000, 32001, or 39030 (Extended entity data linkage)
In V7, these linkages are supported like any other user linkages – in V8, FME stores them as a blob and that gets carried over to V8 as a blob.
Note  To get Extended Entity Data linkages to carry over correctly, the original file containing these linkages should be picked as the seed file. The support for these linkages will work for V8 to V8 only. Any attempt to transfer them from V7 to V8 (or V8 to V7) will not work.
In V8, they store linkage attributes as follows:
Linkage Parameter
Contents
userId
The user -ID of the linkage. This value would be any of 2570, 22244, 32000, 32001, or 39030.
Default: No default
blob
This stores the linkage as binary data.
Default: No default
blobsize
Stores the size of the blob.
Range: 0..256
Default: No default
flags
Flags for the user linkage.
Range: 0..256
Default: No default
type
Type of linkage.
Default: user
