Bentley MicroStation Design (IGDS) Geometry Support
See Also
Geometry
Supported?
Notes
Aggregate
No
Will be deaggregated.
Arc
Yes
Box
Yes
BRep Solid
Yes
Clothoid
No
Will be stroked.
Composite Solid
No
Will be split into component lines.
Composite Surface
No
Coordinate Precision
Full (32-bit)
CSG Solid
No
Donut
Yes
Ellipse
Yes
Extrusion
Yes
Face
No
Geometry Definitions and Instances
No
Each instance will become a copy.
Georeferencing
Native
Hierarchical Geometries
No
Homogeneous Aggregates
No
Line
Yes
Measures
No
Mesh
Yes
MultiArea
No
MultiCurve
No
Multiple Geometries
No
MultiPoint
No
MultiSolid
Yes
MultiSurface
No
Will be deaggregated, will be split into component lines.
MultiText
No
Null
No
Oriented Arc
Yes
Path
Yes
Point Cloud
No
Will be boundary.
Point
Yes
Polygon
Yes
Raster
No
Will be boundary.
Rectangle Face
No
Surface Normals
Yes
Surface Sidedness
Not applicable
Text
Yes
Textures
No
Traits
No
Triangle Fan
No
Triangle Strip
No
Z values
Yes
