Attribute Lists – incosada linkage
If the linkage is an incosada type, then the following attribute names are added by the reader to hold the values for the British Columbia Forestry File (INCOSADA) linkage.
Note  INCOSADA linkages are not supported in Version 8 DGN files, nor are they supported by the Design file writer.
Linkage Parameter
Contents
incosada_fid
The unique feature ID of the linkage.
Range: Character string of size 32 consisting of hex digits
incosada_sequence_num
Sequence number of the linkage.
Range: Integer
incosada_feature_code
The feature code of the INCOSADA feature
Range: Unsigned 32-bit integer
