Attribute Lists – framme linkage
If the linkage is a framme type, the following attribute list item names are used to specify the values for the Facilities Rulebase Application Model Management Environment (FRAMME) linkage.
Familiarity with the FRAMME system is necessary to fully understand the meaning of these attributes.
Note  FRAMME linkages for Version 8 DGN files are only supported for reading.
Linkage Parameter
Contents
ufid
The unique feature ID of the linkage. This is part of the database key used by FRAMME.
Range: Unsigned 32-bit integer
Default: 0
ufid_low
The low order bytes of the unique feature ID of the linkage. This is part of the database key used by FRAMME.
Range: Unsigned 16-bit integer
Default: 0
ufid_high
The high order bytes of the unique feature ID of the linkage. This is part of the database key used by FRAMME.
Default: 0
design_file
The base name of the design file holding the linkage. This makes up the second part of the database key used by FRAMME.
Range: Character string
Default: No default – not used when writing
state_num
The state number of the FRAMME feature
Default: 0
rule_base_id
The FRAMME rule base identifier which is fixed at 0x20.
Range: 0x20 (32 decimal)
Default: 0x20
component_num
The component number of the FRAMME feature.
Default: 0
component_count
The component count, or occurrence, of the FRAMME feature.
Default: 0
feature_num
The feature number of the FRAMME feature.
Default: 0
long{#}
A list of 16-bit words that associated with "long" FRAMME linkages.
Default: 0
For convenience, some of the list item names above are provided as non-list attributes which represent only the first framme linkage found per element.
These attributes are listed below.
Linkage Parameter
Contents
ufid
Range: unsigned 32-bit integer
Default: 0
ufid_low
Default: 0
ufid_high
Default: 0
dgnfile
Range: character string
state_num
Default: 0
comp_num
Range: unsigned 16-bit integer
Default: 0
comp_count
Default: 0
feat_num
Default: 0
