FME Augmented Reality (FME AR) Format Attributes
In addition to the generic FME feature attributes that FME Workbench adds to all features (see About Feature Type Attributes), this format also adds format-specific attributes (Format Attributes).
FME AR assets (features) consist of geometry and geometry attributes. All FME AR assets have one predefined attribute, fmear_type, which identifies the type of the geometry. Geometry types are 3D (x,y,z), and fmear_face can contain texture and normal coordinates.
Attribute Name
Value
fmear_type
The type of geometry read from the table. This attribute will contain the fme_surface geometry type.
Default: No default
fmear_location_feature
Can be set to either anchor or viewpoint. Values are case-sensitive.
  • anchor – Specifies that the feature should be used as an Anchor for the model.
  • viewpoint – Specifies that the feature should be used as a Viewpoint for the model.
Anchor
FME AR supports Anchor, a type of feature that provides additional information to the FME Realize mobile app on how to load the model. An FME AR Anchor may be geolocated, which relates the model to a location in the real world. An FME AR file may only have one anchor provided – anchors beyond the first will be rejected.
A Geolocated Anchor feature must have both the fmear_anchor_latitude and fmear_anchor_longitude attributes with numeric values in LL84 in order to be considered a geolocated anchor.
A non-geolocated Anchor is specified with a Point or Null geometry. If the Anchor feature has no geometry, the model center is used as the anchor point. Anchors may not have other types of geometry set. This type of Anchor is used to specify a specific attachment point in the scene – for example, the corner of a building instead of its center. It is also possible to specify a Z coordinate to change the effective ground level of the model – the value of the Anchor’s Z coordinate will be treated as the surface level when displaying the model. For example, writing a 10-storey building to FME AR along with an Anchor whose Z coordinate corresponds to the floor of the 4th level will cause the FME Realize app to render the building where the 4th floor is flush with the display surface. Similarly, changing the Anchor’s Z coordinate so it corresponds with one of the underground parking levels will cause the FME Realize app to render the building with that underground level flush with the detected surface.
A Geolocated Anchor may be combined with a non-geolocated Anchor to both correlate the model to a physical location and modify the model’s attachment point. They must be combined into a single feature to perform this function.
Anchor features will be checked for FME AR metadata attributes, but otherwise their attributes will not be written. Do not tag features with desired 3D geometry as an anchor. Rejected Anchors will not be checked for metadata. Anchors that reach the writer after the first valid anchor is found will be rejected. Avoid creating workspaces where more than one Anchor feature will be created.
Attribute Name
Function
The latitude the model’s origin maps to in LL84.
The longitude the model’s origin maps to in LL84.
Viewpoints
In order to be able to easily teleport between different points within a model, an FME AR file may contain a number of Viewpoints, which, when viewed with a supported app, allow users to recenter the view on them. This allows multiple points of interest on a model to be reached quickly.
A feature with the attribute fmear_location_feature set to viewpoint and containing a Point geometry will be recorded in the output file as a viewpoint. Features that have the attribute but are not points will cause a warning to be logged. Viewpoints may be specified with either 3D or 2D points. In the case of 2D, (Z = 0) will be assumed.
You can (optionally) name a viewpoint by using a GeometryPropertySetter transformer to set the geometry label.
Viewpoint features will be checked for FME AR metadata attributes, but otherwise their attributes will not be written. Viewpoint features with null geometries or a geometry type other than Point will be rejected. Rejected Viewpoints will not be checked for other metadata.
FME AR Metadata
FME AR supports certain metadata keys that will be written to the output file that can affect how the model is displayed. These values are specified as format attributes and each valid feature will be checked for these. Only the first value found for each individual key will be used and subsequent values will be ignored by the writer.
Note  The writer will use the first valid value it finds as features are written. Once a correctly formatted date value is found, subsequent features will not be checked for this attribute. Invalid values will cause a warning to be logged and subsequent features will still be checked for that key.
Model Expiration Date
When a model is meant to have a fixed lifetime, the fmear_model_expiry metadata attribute can be specified. The value must be expressed as an FME-format date in order to be considered valid. Other values will be logged and will not be used.
When the expiration date has passed (according to the mobile device’s system clock), a notification will be displayed that the model is no longer valid for use. For example, this can be used when an authorization to excavate near underground gas or power lines has been issued and the authorization has a fixed lifetime. A model’s expiration date can match the expiration of the authorization in this case.
Visibility
FME AR supports controlling the visibility of a model asset when first loaded in the FME Realize mobile app. The visibility of each asset can be controlled with the fmear_visible attribute. An asset will be visible by default if fmear_visible is set to true and will be hidden by default if it is set to false. If a value is not set for fmear_visible, then the default value set in the Feature Type Parameters will be used.
Attribute Name
Function
fmear_visible
Control the visibility of the asset.
Range: Boolean value
Default: Visible value set in parameters
Occlusion
Allows creation of occluder meshes that will hide the virtual geometry when it appears behind an occluder. This can be used to approximate real-world objects blocking the view of the superimposed geometry.
Occlusion is controlled with the fmear_occlusion attribute. An asset will be considered an occluder when the attribute value is set to true. A default may be set per feature type.
Objects with occlusion will be able to be toggled on and off in the FME Realize app.
Attribute Name
Function
fmear_occlusion
Controls whether the geometry of the feature is occluding .
