Feature Type and Attribute Property Menus
Jump to:
Working with Reader Feature Types
Right-click on a Feature Type, and choose an option from the command menu.
Menu choices for reader feature types
Menu Choice
Description
Run
You can run partial workspaces in the following ways:
  • Run From This (or Selected) (F6): All parts of the workspace that flow from a selected object (or objects) run.
  • Run Just This (or Selected): Only a selected object (or objects) runs. If a collapsed bookmark is included in the selection, only the objects within the bookmark run.
  • Run To This (or Selected) (Shift+F6): All parts of the workspace that flow to a selected object (or objects) run.
  • Run Between Selected: All parts of the workspace that flow between the selected objects run.
Cut, Copy, Delete
Performs these functions on the selected feature type only.
Duplicate on Writer
Duplicates the feature type on the writer side, and automatically connects all the attributes.
Disable
Disables this feature type. Menu selection changes to Enable when the feature type has been disabled.
Hide (Connections)
Hides the connections to and from a transformer or feature type. The menu selection changes to Show when connections are hidden.
Enable Only This Feature Type
Disables (and grays out) all other feature types
Connect Inspector
Connects an Inspector transformer.
Connect Logger
Connects a Logger transformer.
Connect Junction
Connects a junction. Junctions help manage connections as you build and organize a workspace.
Attach Annotation
Add a comment associated with this feature. The comment, connected by a leader line will stay joined to its associated feature type.
Show Summary Annotation
Shows hidden object information. This can be useful when printing a workspace.
Create Bookmark
Define areas of your workspace for easy access.
Copy Attributes from Feature Type/Transformer
Copy attributes from another feature type or a transformer. This is a useful function if you have many attributes to duplicate.
Bring to Front, Send to Back
Useful if you have a large workspace, with many feature types.
Zoom to Feature Type
Zooms and focuses the canvas on the selected feature type.
Update
If you add or rename an attribute, this function allows you to update feature types without having to remove and reload them.
Expose Attributes
For advanced FME users: allows you to "expose" or make visible built-in FME attributes.
Pair With
Connects selected reader and writer feature types.
Disconnect
Removes all connections.
View Source Data
Displays the data in the the FME Data Inspector.
Open Containing Folder
Opens the folder that contains the source data.
Properties
Rename the feature type, or view or edit the feature type parameters and attributes. (This is the same as clicking the gear icon above the feature type.)
Working with Writer Feature Types
Menu choices for writer feature types
Menu Choice
Description
Run
  • Run From This (or Selected): All parts of the workspace that flow from a selected object (or objects) run.
  • Run To This (or Selected): All parts of the workspace that flow to a selected object (or objects) run.
Cut, Copy, Delete
Duplicate
Duplicate this feature type on the writer.
Disable
Hide (Connections)
Update
Attach Annotation
Allows you to add a comment associated with this feature. The comment, connected by a leader line, will stay joined to its associated feature type.
Show Summary Annotations
Shows hidden object information. This can be useful when printing out a workspace.
Create Bookmark
Duplicates the attributes from another feature type.
Copy Attributes from Transformer
Duplicates the attributes from a transformer.
Expose Attributes
Sort Attributes
Alphabetizes the attribute names.
Add Attribute
Adds a new attribute. Note that you will have to physically connect this attribute with its source.
Rename (F2)
Type a new name and press Enter.
Pair With
Connects selected source and destination types.
Disconnect
View Written Data
Displays the data in the FME Data Inspector.
Open the folder that contains the output data.
Edit (Writer) Parameters
Opens a dialog that displays the existing parameters set on the writer.
Properties
Rename the feature type, or view or edit the feature type parameters and attributes. (This is the same as clicking the gear icon on the top right-hand side of the feature type.)
Working with Attributes
Right-click on either a reader or writer attribute, and choose an option from the command menu.
Menu choices for editing attributes
Note  To enable the menu choices, click the gear icon above the feature type, click the User Attributes tab, and select Manual under Attribute Definition.
Menu Choice
Description
Edit Value
Assign a fixed value to the attribute (writer attributes only).
This was known in previous FME versions as Constant Value.
Rename
Note  You will lose any association with any previously connected attribute.
Delete Remove attribute from the list.
Move Up/Down
Moves the attribute up or down in the list. You might want to do this so the display looks visually cleaner, or to organize attributes for ease of reference.
Properties Rename, view, or edit the attribute. (This is the same as clicking the gear icon above the feature type, and clicking the User Attributes tab.)
