FME Form: 2026.3
FME Packages
Select Utilities > FME Options > FME Packages.
View, update, or remove any of the FME Packages that are installed on your FME Form.
Adding Packages
Packages are available for download from FME Hub.
Updating a Package
Updating a package pulls the latest version from FME Hub.
- Click Check for Updates.
- After the update check completes, select the package you want to update. If the Update button is enabled, an update is available for the selected package. Additionally, (Update Available) is appended to the package name.
- Click Update.
Incompatible Packages
If an update is available for a package that is not compatible with the current version of FME, a banner displays with a link to update. Links for updating incompatible packages are also available in the following places:
- The Quick Add dialog.
- The Add Reader or Add Writer dialog.
- The Reader and Writer Gallery.
- A dialog that appears when opening a workspace containing one or more incompatible packages.
Removing a Package
Removing a package removes all components from FME Workbench that were contained in the package.
Select the package you want to remove and click Remove.
