FME Transformers: 2026.3
Installing the JMS Libraries
An installation of FME Form includes the libraries that are required for using JMS messaging with Apache ActiveMQ 5.6.0. For all other message brokers, vendor-specific JMS libraries must be acquired and installed alongside FME Flow.
Typically, vendor-specific JMS libraries are either available in the message broker’s installation, or available in a separate message broker client. In the case of IBM WebSphere MQ 7, for example, a separate client installation is available.
The table below provides links to appropriate software. For additional information, consult your vendor's documentation.
To install the JMS Libraries
  1. Download and install the software containing the vendor-specific JMS implementation library to the machine with the installation of FME Form.
  2. Locate the required libraries. (See the table below, under "Libraries.")
  3. Copy the libraries to the \plugins folder, located directly under the root directory of your FME installation.
Message Broker Libraries Sample Path (Windows)
Apache ActiveMQ none (Apache ActiveMQ 5.6.0 libraries bundled with FME Form) --
IBM WebSphere 7
com.ibm.mq.jmqi.jar
com.ibm.mqjms.jar
dhbcore.jar
fscontext.jar
providerutil.jar
C:\Program Files (x86)\IBM\WebSphere MQ\java\lib
IBM MQ 9.2
com.ibm.mq.allclient.jar
jms.jar
fscontext.jar
providerutil.jar
C:\Program Files\IBM\MQ\java\lib
HornetQ
hornetq-jms.jar
hornetq-jms-client.jar
jnp-client.jar
C:\hornetq-x.y.z\lib
Oracle Weblogic wlthint3client.jar
What's Next?
Depending on your message broker, additional configuration may be required to enable JMS. See Configuring the JMS Provider
