FME Transformers: 2025.1
Multiple Geometries
A multiple geometry is a collection containing parts that are interpreted to be independent geometries. Each part is treated as its own complete geometry, separate from other parts. Each part may have a separate coordinate system. Each part is required to have a unique name.
For example, a multiple geometry may contain two parts, one named Area containing an area representation of a feature, and one named Point which contains a point representation of the same feature.
Multiple geometries are a different concept from multi geometries, such as MultiPoint and others.
Multiple geometries are often successfully handled in the same way aggregate geometries are handled, even though they are conceptually slightly different than aggregates.
MultipleGeometrySetter and MultipleGeometryFilter are two transformers that are helpful to use with multiple geometries in a workspace. Several database formats support reading and writing of multiple geometries.
Multiple Geometry Attributes
  • fme_geometry = fme_aggregate
  • fme_type = fme_collection
