FME Transformers: 2026.1
fme_type
In addition to the fme_geometry attribute which indicates what the coordinates of an FME feature are, each FME feature also has an fme_type attribute which controls the interpretation of those coordinates. For example, a feature with fme_geometry of fme_point may be used to represent a point, a text object, an arc, or an ellipse. The value of the fme_type attribute is used to indicate which interpretation should be made.
The fme_type attribute can have one of a set number of values. Depending on the value of fme_type, there may be additional attributes required to fully interpret the geometry.
The following table lists the allowed values for fme_type, the associated fme_geometry, and its additional attributes.
fme_type
fme_geometry
Additional Attributes
fme_arc
fme_point
fme_rotation
The rotation of the primary axis in degrees counterclockwise from the primary axis. If not set, then 0 is assumed.
fme_primary_axis
The length of the primary semi-axis of the defining ellipse measured in ground units.
fme_secondary_axis
The length of the secondary semi-axis of the defining ellipse measured in ground units. For circular arcs this value will be equal to the fme_primary_axis.
fme_start_angle
Copy
<startAngle>
      arctan((fme_primary_axis/fme_secondary_axis)*tan(realStartAngle))
  • Default – 0
  • Range – Real Value
fme_sweep_angle
Copy
<sweepAngle>
      arctan((fme_primary_axis/fme_secondary_axis)*tan(realEndAngle)) -
  • Default – 360
fme_any
Accepts any potential geometry (except text)
Various
fme_area
fme_polygon or
fme_donut or fme_aggregate
None
fme_collection
fme_aggregate
None
fme_ellipse
fme_point
fme_rotation
The rotation of the primary axis in degrees counterclockwise from horizontal. If not set, then 0 is assumed.
fme_primary_axis
The length of the primary semi-axis of the ellipse measured in ground units.
fme_secondary_axis
The length of the secondary semi-axis of the ellipse measured in ground units. For circles this value will be equal to the fme_primary_axis.
fme_line
fme_line or fme_aggregate
None
fme_no_geom
fme_undefined
None
fme_point
fme_point or fme_aggregate
None
fme_raster
fme_aggregate
None
fme_solid
fme_aggregate
None.
Note  fme_solid is the fme_type for the following geometries: Extrusion, Box, BRepSolid, CSGSolid, and CompositeSolid.
For more information, see Surface and Solid
fme_surface
fme_aggregate
None.
Note  fme_surface is the fme_type for the following geometries: Face, RectangleFace, TriangleStrip, TriangleFan, and CompositeSurface.
fme_text
fme_point
fme_rotation
The rotation of the text in degrees counterclockwise from horizontal. If not set, then 0 is assumed.
fme_text_string
The actual annotation string.
fme_text_size
The height of the text measured in ground units.
Note  Any features with an fme_geometry value of fme_aggregate, and an fme_type other than fme_collection must be homogeneous aggregates. An fme_type of fme_collection allows the feature to have heterogeneous aggregate geometry.
