XSD-Driven XML User Attributes
To access user attributes, click the Parameters button on a feature type in the workspace, and select the User Attributes tab.
The following table shows the attribute types that are supported.
Name
A simple attribute, a list attribute, a structured attribute, or a geometry attribute.
Simple attributes
These attributes have no embedded period, and they are mapped into simple type properties in the GML application schema.
List attributes
These attributes end with a “{}” suffix, and are mapped into simple type property declarations whose maxOccurs are set to unbounded.
Structured attributes
These attributes have embedded periods: each component in a structured attribute is separated by a period, and each component may also be a list. Structured attributes are mapped into complex type properties in the XSD schema. For example, the structured FME attributes, “changeHistory.Date”, and “changeHistory.Reason” are mapped into a changeHistory element whose complex type is defined as a sequence of Date and Reason elements both of which are defined as simple types.
Type
This format supports the following field types.
xml_boolean
This type corresponds to an XML built-in data type.
xml_buffer
Mapped to an unlimited length string, xs:string, or text buffer type.
xml_byte
xml_char(width)
Mapped to the xs:string with a length or maxLength facet.
xml_date
xml_datetime
xml_decimal
xml_int16
xml_int32
xml_int64
xml_real32
xml_real64
xml_time
xml_ubyte
xml_uint16
xml_uint32
xml_uint64
xml_xml
Used by the reader and writer to denote that an attribute name holds an XML fragment. There is no corresponding XML schema type.
Width
The width parameter controls the maximum characters that can be stored by the field.
Precision
For some attribute types, controls the precision of the data by specifying the number of digits to the right of the decimal.
