U.S. Geological Survey Digital Elevation Model (USGSDEM) Feature Representation
In addition to the generic FME feature attributes that FME Workbench adds to all features (see About Feature Type Attributes), this format also adds format-specific attributes (Format Attributes).
USGS DEM data can be represented in two different ways in FME: FME raster features and FME point features.
FME Raster Features
FME raster features are the preferred, faster way. The method of FME feature reading can be set using the Read as DEM Raster reader parameter.
For FME raster feature reading, each USGS DEM file is represented by a single feature with a feature type of Elevation_raster. All data is stored on this feature including elevation data, record type A header information, and record type C statistical information if it exists.
FME Point Features
For FME point feature reading, except for possibly the last feature, all features read from USGS DEM files are 3D points with feature types of Vertical. If record type C exists in a USGS DEM file, then the last feature will be a feature containing information found in record C. This feature will not have any geometry because record C does not represent any type of geometry. Record C contains statistics about the accuracy of the data in the USGS DEM file.
Attribute Name
Contents
dem_type
The USGS DEM geometric type of this entity.
Range: dem_raster|dem_point|dem_record_C
Default: No default
Rasters
dem_type: dem_raster
USGS DEM raster features specify a matrix of x, y, and z coordinates. If known, the coordinate system will be specified.
Attribute Name
Contents
dem_file_name
This is a string that specifies the basename of the raster file.
dem_producer
This is a string that specifies the producer of the data.
dem_process_code
This is a one-byte integer that specifies how to the data is processed.
Range: 1...8
Default: 8
dem_sectional_indicator
Unique to 30-minute DEMs, this 3-character string identifies 1:100,000-scale sections.
dem_origin_code
This is a 4-character string that specifies the mapping origin.
dem_level_code
This is an integer defining the DEM level. FME will not determine or check the validity of this assertion.
Level 1: 7.5-minute or 30-minute DEM created by autocorrelaton or manual profiling from aerial photographs.
Level 2: DEM created from digital line graph contours or equivalent, from any USGS map series up to 1:100,000 scale.
Level 3: 7.5-minute DEM created from a digital line graph that has vertically integrated with all categores of hypsography, hydrography, ridge line, break line, drain files, and all vertical and horizontal control networks.
Level 4: DEM created from electronic imaging sensor systems.
Range: 1-4
Default: 1
dem_code_defining_elevation_pattern
This specifies the regularity of the elevation pattern.
Range: regular|random
Default: regular
dem_accuracy_code_for_
elevations
A number that specifies the existence of accuracy information for this dataset. 0 indicates unknown accuracy information.
Range: 0|1
Default: 1
dem_spatial_
resolution_z
A positive real number used to specify a scale to apply to the elevation values in the z dimension. When specified for the writer, elevation values will be scaled appropriately. This value is tied with the value of dem_units; resolutions of 1 decimal place for feet and 2 decimals places for meters are permitted.
Default: 1
dem_units
The unit of measure for the z coordinate (the altitude).
Range: meters|feet
Default: No default
dem_largest_primary_
contour_interval
Unique to level 2 DEMs, this integer specifies the largest primary contour interval if two or more primary intervals exist. If this field is not provided to the writer, it will be left blank.
contour_interval_units
Unique to level 2 DEMs, this corresponds to the units of the largest primary contour interval. If this field is not provided to the writer, it will be left blank.
Range: N.A.|meters|feet
dem_smallest_primary_
contour_interval
Unique to level 2 DEMs, this integer specifies the smallest or only primary contour interval. If this field is not provided to the writer, it will be left blank.
Unique to level 2 DEMs, this corresponds to the units of the smallest primary contour interval. If this field is not provided to the writer, it will be left blank.
dem_data_source_date
This specifies the year that the original compilation data was formed. If this field is not provided to the writer, it will be left blank.
dem_data_inspection_and_revision_date
This specifies the year of the date of completion or revision. If this field is not provided to the writer, the current year will be used.
dem_inspection_flag
This flag is blank if quality control has not been performed. Otherwise, it is flagged as “I” to indicate that all quality control processes are complete. If this field is not provided to the writer, it will be left blank.
dem_data_validation_flag
This single-digit integer specifies the type of data validation performed.
Range: 0-5
Default: 0
dem_suspect_and_void_
area_flag
This is a one-digit integer that indicates if the data contains void areas. If this field is not provided to the writer, it will be left blank.
Range: 0-3
dem_data_edition
This is a four-digit integer specifying the data edition or version used.
Range: 0...9999
Default: 1
dem_percent_void
This is an integer equal to the percentage of nodes in the file set to void (-32767). This is only populated if the dem_data_edition field indicates a void. If this field is not provided to the writer, it will be left blank.
Range: 0...100
dem_edge_match_flag_WEST
This integer flag specifies if edge-matching is required on the western edge of the raster. If this field is not provided to the writer, it will be left blank.
Range: 1-4
NORTH
This integer flag specifies if edge-matching is required on the northern edge of the raster. If this field is not provided to the writer, it will be left blank.
Range: 1-4
dem_edge_match_flag_EAST
This integer flag specifies if edge-matching is required on the eastern edge of the raster. If this field is not provided to the writer, it will be left blank.
Range: 1-4
SOUTH
This integer flag specifies if edge-matching is required on the southern edge of the raster. If this field is not provided to the writer, it will be left blank.
Range: 1-4
dem_vertical_datum_shift
This number specifies the value to add to convert to NAVD88. If this field is not provided to the writer, it will be left blank.
file_datum_stats_avail
The code indicating the availability of the statistics in attributes ‘file_datum_rmse_[x|y|z]’.
0 = unavailable, 1 = available
Range: 0|1
Default: No default
file_datum_rmse_x
RMSE of file’s datum relative to absolute datum (for the x-coordinate).
Range: 0...999999
Default: No default
file_datum_rmse_y
RMSE of file’s datum relative to absolute datum (for the y-coordinate).
Range: 0...999999
Default: No default
file_datum_rmse_z
RMSE of file’s datum relative to absolute datum (for the z-coordinate).
Range: 0...999999
Default: No default
file_datum_sample_size
Sample size on which statistics for attributes ‘file_datum_rmse_[x|y|z]’ are based.
Range: 0...999999
Default: No default
dem_datum_stats_avail
The code indicating the availability of the statistics in attributes ‘dem_datum_rmse_[x|y|z]’.
Range: 0|1
Default: No default
dem_datum_rmse_x
RMSE of DEM datum relative to file’s datum (for the x-coordinate).
Range: 0...999999
Default: No default
dem_datum_rmse_y
RMSE of DEM datum relative to file’s datum (for the y-coordinate).
Range: 0...999999
Default: No default
dem_datum_rmse_z
RMSE of DEM datum relative to file’s datum (for the z-coordinate).
Range: 0...999999
Default: No default
dem_datum_sample_size
Sample size on which statistics for attributes ‘dem_datum_rmse_[x|y|z]’ are based.
Range: 0...999999
Default: No default
Point Data
dem_type: dem_point
USGS DEM point features specify a single x, y, and z coordinate. If known, the coordinate system will be specified.
Attribute Name
Contents
dem_units
Range: meters|feet
Default: No default
Statistical Data
dem_type: dem_record_C
This feature contains all the data found within record C. By definition, record C does not contain any geometry; rather, its purpose is to hold statistics about the accuracy of the data within the USGS DEM file.
Attribute Name
Contents
Range: 0|1
Default: No default
file_datum_rmse_x
Range: 0...999999
Default: No default
file_datum_rmse_y
Range: 0...999999
Default: No default
file_datum_rmse_z
Range: 0...999999
Default: No default
Range: 0...999999
Default: No default
Range: 0|1
Default: No default
dem_datum_rmse_x
Range: 0...999999
Default: No default
dem_datum_rmse_y
Range: 0...999999
Default: No default
dem_datum_rmse_z
Range: 0...999999
Default: No default
Range: 0...999999
Default: No default
