SAP Sybase ASE Writer: User Attributes
User attributes for this format are defined below.
Name The name of the field to be written.
Type
This section describes the attribute types for a table.
Index
The types of indexes and constraints to create for the column, if the table is created.
Each index and constraint contains only one column.
The valid values for the column type are listed below:
PrimaryKey: This type specifies that the column is a primary key for the table. Only one primary key is allowed per table.
Unique: This type specifies that the column has a UNIQUE constraint.
NotNull: A non-nullable constraint.
Null: A nullable constraint.
