PostGIS Raster: Add Database Connection
To define a new connection from the Connection parameter in a PostGIS format:
  • Select Add Database Connection. See database-specific parameters below, as well as the section Adding a Database Connection in a Workspace in Using Database Connections The new connection can be made visible only to the current user, or can be shared among multiple users.
Note  To select an existing, previously defined connection, see the section Reusing a Database Connection in Using Database Connections
Database Connection
PostgreSQL (PostGIS is a geometric layer over a PostgreSQL ORDBMS.)
Name
Enter a name for the new connection. Entering a descriptive name allows you to easily find the connection in future workspaces.
The following characters are not allowed in connection names: ^ \ / : * ? " < > | & = ' + % #
Connection Parameters
Note  If you are having trouble connecting to the database, ensure you can connect to the database with the host, port, database, username, and password using psql. See PostgreSQL documentation for proper security and connection information, and for the usage of the psql utility.
SSL Options
