STAC Metadata Format Attributes
In addition to the generic FME feature attributes that FME Workbench adds to all features (see About Feature Type Attributes), this format also adds format-specific attributes (Format Attributes).
To open Format Attributes, click the gear icon on a feature type in the workspace. Then click the Format Attributes tab. Format Attributes are applicable only to the selected feature type in the workspace.
STAC Metadata Feature Type
The format-specific attributes for a STAC metadata feature type are listed below.
Attribute Name
Type
Contents
stac_metadata_type
str
The geometry of the dataset. This will always be stac_metadata_none because the reader does not add any geometries to output features.
stacmetadata_href
str
The URL to the Item, Catalog, or Collection.
stacmetadata_id
str
The unique identifier of the Item, Catalog, or Collection.
stacmetadata_json_response
json
The entire JSON response when requesting the Item, Catalog, or Collection.
stacmetadata_links{}.href
str
The URL to another entity from the links property of an Item.
stacmetadata_links{}.rel
str
The relationship between the current Item and the linked entity.
stacmetadata_links{}.title
str
The display title for the linked entity.
stacmetadata_links{}.type
str
The media type of the linked entity.
stacmetadata_stac_extensions{}
list[str]
A list of extension identifiers the Item, Catalog, or Collection implements.
stacmetadata_type
str
The type of STAC object. Note that an Item is recognized as a “Feature” type.
Item Metadata Feature Types
The following format-specific attributes are for Item metadata feature types only:
Attribute Name
Type
Contents
stacmetadata_bbox{}
list[float]
The bounding box of the Item.
stacmetadata_collection
str
The unique identifier of the Collection that the Item belongs to, if it exists.
stacmetadata_geometry
json
The full footprint of the assets represented by this Item. Coordinates are specified in Longitude/Latitude or Longitude/Latitude/Elevation based on WGS84.
stacmetadata_assets{}.description
str
A description of the asset providing additional details.
stacmetadata_assets{}.href
str
The URL to an asset of the Item.
stacmetadata_assets{}.id
str
The unique identifier of an asset of the Item.
stacmetadata_assets{}.roles{}
list[str]
The role(s)/purpose of an asset of the Item.
stacmetadata_assets{}.title
str
The display label for an asset of the Item.
stacmetadata_assets{}.type
str
The media type of an asset of the Item.
Catalog/Collection Metadata Feature Types
The following format-specific attributes are for Catalog/Collection metadata feature types only:
Attribute Name
Type
Contents
stacmetadata_description
str
A detailed multi-line description to fully explain the Catalog/Collection.
stacmetadata_title
str
A short, descriptive one-line title for the Catalog/Collection.
