Pinecone: Add Web Connection
To define a new connection from the Pinecone Connection parameter in the Pinecone format:
Select Add Web Connection. See the connection parameters below, as well as Using Web Connections. The new connection can be made visible only to the current user, or can be shared among multiple users.
Connection Parameters
Web Service
Pinecone (safe.pinecone.Pinecone)
API Key
A Pinecone API key. Create or copy one from the Pinecone console under API Keys. The key's project determines which indexes the reader can see.
The key needs the Control Plane Viewer role to list indexes and the Data Plane Viewer role to read records (or a role that includes them). If a role is missing, the reader's error message names it.
Controller URL (optional)
Leave blank to connect to Pinecone cloud. For Pinecone Local, enter the local controller URL, for example http://localhost:5080. Pinecone Local accepts any API key value.
Verify SSL Certificates
The reader follows this setting. On Windows, it trusts certificates in the Windows certificate store, as FME does. The SSL_CERT_FILE and SSL_CERT_DIR environment variables take precedence on every platform.
Proxy Support
The reader connects through the proxy in FME's network settings, including a proxy auto-config (PAC) file, the Custom Proxy Map and non-proxy hosts. Only HTTP and HTTPS proxies with Basic authentication are supported; SOCKS proxies in a PAC file are skipped. Pinecone Local on the same machine is always reached directly.
Using the Connection in HTTPCaller
The connection adds the Api-Key header to requests. The Controller URL is not applied, so enter the full request URL in the HTTPCaller transformer.
